How to use StringSearcher function in AttributeManager?
Hi all,
Can the AttributeManager perform operations like the StringSearcher?
I would like to extract certain strings from an attribute called RAW_DATA, I'm looking for the value in "value="xxx"
e.g.
<span class="store-card__value">Mon-Fri 09:00 AM  - 09:00 PM
</span>
<span class="store-card__value">Sat 09:00 AM  - 06:00 PM
</span>
<span class="store-card__value">Sun 10:00 AM  - 05:00 PM
</span>
</p>
</div>
<div>
</div>
<div class="store-card__section">
<a class="store-card__action" href="/teststore.com">Store Details</a>
<button class="btn btn-tool store-card__action storeSelectButton selectCategoryStore " id="selectCategoryStore_699" name="699" value="699">Store</button>
</div>
</section>
</li>
In a StringReplacer I would use RegEx like value=\"\d{1,3}\" to get what I need.
I have to perform a bunch of operations like the above one so I'd rather keep everything in one AttributeManager and not use 20 separate StringReplacers.
Can the AttributeManager perform these operations?
I have been looking at the help file but it is not clear to me. Stuff like this is just Chinese to me:FindString(str, findStr, [startIdx], [caseSensitive])
Returns the index in string
str
starting at
startIdx
that matches
findStr
, or -1 if the string is not found. If
startIdx
is a negative integer,
FindString()
 returns the index in
str
starting at
startIdx
 from the end of
str
, then matching
findStr
going forward (from left to right). If
startIdx
is not specified, the search starts at index 0. If
caseSensitive
is FALSE, the search is case-insensitive. Otherwise, the search is case-sensitive.
Cheers,
Ed
Forum|alt.badge.img+39
  • January 23, 2020
There is no function in the AttributeManager to return a regex match, you can return the start position of a match or replace a regex match but not return the match itself. There are ways a means to achieve the same thing sometimes but they're not straightforward
gabriel_hirsch
Forum|alt.badge.img+12
It seems that you are working with HTML data. Have you tried the HTMLExtractor transformer to retrieve the information needed?
  • January 23, 2020
@edhere Your choices are probably:
  • StringSearcher - but as you say you might need lot's of them, but much easier to formulate the regex
  • AttributeCreator/Manager with FindRegEx and Substring. FindRegEx gives you the location of your string and the Substring extracts it. Pretty complex and probably harder to maintain than several StringSearcher's
  • Treat it as an HTML problem as suggested by @gabriel_hirsch. But convert the HTML to XML (HTMLToXHTMLConverter) and then use XMLFlattener to extract the attribution you need.
I've attached an example workspace with all three options (2019.2): xmlextract.fmw
  • January 24, 2020
Hi all,
Thanks for all the replies. Apparently one does not simply use StringReplacer inside an AttributeManager ;-)
I'll have a look at the examples. I might still choose a bunch of StringReplacers and tuck them away in a bookmark!
