how to save IFMEPolygon
  • Jan 9, 2021 3:25 AM UTC
  • 47 views
Dear Sir or Madam:
I am using FME to convert s57 to shapefile, but I cannot save the information below IFMEPloygon( the information in the red rectangle in the below picture).
Can you give me some tips?
Thank you very much.
微信图片_20210108135641
A CoordinateExtractor will create a list of the coordinates from the FME geometry, a OrientationExtractor will tell you the orientation, and ConvexityFilter will tell you if it's convex or concave.
I think you can also use the GeometryPropertyExtractor. (never had the need for the other attributes, so I don't know if that does what you want)
@gaojiang109​  "I cannot save the information" would usually result in an error or warning. Can you let us know what error message or warning you receive in the FME log file or other message that might help us isolate the problem?
