How to reduce vertex count in line feature?
  • November 1, 2022
  • 138 views
saravanakumar
Forum|alt.badge.img+5
Hi all,
Is there any transformer to reduce the no of vertex in line feature?
I am using autocad data dwg format. there is large no of vertex in a line feature which you can able to see below image. Is it possible to reduce the number of vertex? and I tried with line combiner Its not reducing no of vertex.
image.pngthanks ,
saravanakumar.
f.kemminje
Forum|alt.badge.img+11
  • November 1, 2022
We have a transformer called Generalizer
Generalizer
Transforms or measures geometry features based on a specified algorithm.
There are four types of algorithms:
  • Generalizing algorithms: Reduce the density of coordinates by removing vertices.
  • Smoothing algorithms: Determine a new location for each vertex.
  • Measuring algorithms: Calculate the location of points, and return a list of these points (for example, to measure the sinuosity of a feature).
  • Fitting algorithms: Replace the original geometry completely, with a new feature fitted to a specified line (for example, to minimize the orthogonal distance to the original).
read link
https://community.safe.com/s/article/reducing-unnecessary-coordinates
  • November 1, 2022
@saravanakumar​ As @f.kemminje​ suggest - Generalizer is the place to start. But depending on the data you want to thin, you might also try CurveFitter or SherbendGeneralizer
f.kemminje
  • November 2, 2022
Thanks!@Mark Stoakes​
saravanakumar
  • November 2, 2022
Thank @f.kemminje​  and @Mark Stoakes​  for your valuable suggestions. I will use those and try 😀 .
