how to prepare 3D geometry for CSGBuilder?
  • November 22, 2013
  • 54 views
makt
If I start with a coordinate pair or shapefile, and then use the extruder(s) to create a volume, what transformer do I need next so that the CSGBuilder will recognize the volume as "proper" 3D shape? I've tried GeometryFilter (solid) and GeometryCoercer (fme_brep_solid) but these do not do the trick.
Here is an example that is easily tweeked to replicate my problem:
http://fmepedia.safe.com/articles/How_To/Using-the-CSGBuilder-Transformer
This example creates XML geometry (an ellipse) then extrudes it and sends it to CSGBuilder. How can I make this work if I start with a shapefile that is an ellipse?
Best answer by fmelizard
This example you mention is quite straight forward and simple, have you tried it?  What is the error message you get if it fails?
Itay
fmelizard
Forum|alt.badge.img+22
  • November 23, 2013
Itay
