How to mosaick the DTM rasters by inerpolating their cell sizes (e.g. 1m) ?
  • Jun 23, 2020 9:38 AM UTC
  • 87 views
kahramannkadirr
Participant
Hello everyone.
I have a question for my DTM imageries. Resolution of imageries are 0.15m for red bordered area and 0,70 m. for green bordered area. I want to create a merged (mosaicked) and interpolated raster with a resolution of 0,50 m.. By the way; intersection of the two areas must come from the high resoluiton. How i must set the overlapping value and in what order should it be the transformers?
I can guess the transformers that i can use (like rasterressampler, rastercellcoercer, rasermosaicker, tester(to retrieving the cells from high resolution for intersection area), 3DForcer, SurfaceModeler, etc.)
Thanks.
@daleatsafe @daveatsafe @jovitaatsafe @redgeographics @deanatsafe @rylanatsafe @hollyatsafe @lenaatsafe @annabelleatsafe @steveatsafe
Best answer by jlbaker2779
Use a clipper to cut out the red area from the original, mosaic them together, and then resample.
  • Jun 23, 2020 10:32 AM UTC
Hi @kahramannkadirr, I think the RasterResampler is suitable to your requirement.
  • Jun 23, 2020 10:35 AM UTC
