How to manage input order ?
  • April 3, 2014
  • 109 views
I've got a workbench which look like this:
  Reader --> T1 ---------->Aggregator -> Writer
                 -> CT1 -|
                 -> CT2 -|
Every feature has an "id" and the aggregator groupd them with the "id"
T1 is a simple transformer (like AttributeCreator).
CT1 and CT2 are custom transformer very complicated with many steps (~20 each without the same length).
Because i've got ~1million element in the Reader, in the Aggregator I which I could select the "Input is ordered by group" for "performance" issues.
But it does not work; I've got only the T1 output.
So, How may I do this ?
For feeding the pipe I though of "no-op" block like in electronic ... but it's does not exist and it's a pain to do.. and not very reliable.
Is there something else I could do / use ?
gio
Forum|alt.badge.img+15
  • April 3, 2014
If every item has an (unique)ID then grouping on that ID is not very usefull for perfomance gain.
If u want the gain and the ability to use paralel processing you should create some grouping strategy.
U could use a gridbuilder, or a tiler strait at the beginning of the bench. I usualy use ie neighborhoodnames or create some grid. Teh attributes must be passed all trough the processing. Alos take care to keep the correct instances of these "group_D's"
This also fascilitates paralell processing.
Greets
Gio
  • April 4, 2014
You're right: it's not very useful for performance, but it's mendatory for database insertion.
