How to keep attributes from both overlapping features when doing a spatial join?
  • Apr 17, 2018 9:27 PM UTC
  • 7 replies
  • 202 views
Hi everyone. I have 2 esri shapefile polygons. I need to do spatial join of those 2. Features that overlap should have attributes from both input layers. I tried areaonareaoverlayer but the result is not good. Can anybody help? Thanks!
  • Apr 17, 2018 10:09 PM UTC
Hi @delac321, if you need to combine the two overlapping polygons to create a single polygon, try using the Dissolver transformer. You can use the 'Generate List' option to preserve required attributes of original polygon features.
danilo_fme
Forum|alt.badge.img+58
  • Apr 17, 2018 11:28 PM UTC
Hi @delac321
The transformer AreaonAreaOverlayer has the option Generate List that is possible to combine the Attributes, when you work with spatial join between two polygons.
Thanks,
Danilo
  • Apr 18, 2018 1:02 PM UTC
Hi @delac321
Thanks,
Danilo
Thanks a lot.
Thanks a lot.
danilo_fme
  • Apr 18, 2018 1:21 PM UTC
Thanks a lot.
You are Wellcome!
  • Apr 18, 2018 1:27 PM UTC
Thanks a lot. I partly managed. Resulting features have attributes from both input layers, but lists contain only first value, and in some cases should be more but the other lists fields are empty. Any thoughts?
danilo_fme
  • Apr 18, 2018 2:35 PM UTC
Hi @delac321
Please, try to expose the list elements with the transformer ListExploder.
Thanks,
Danilo
