How to join two datasets without a common field
  • July 18, 2016
  • 109 views
gisgeek
Forum|alt.badge.img+9
I have two datasets - I want to join them I guess like a union but don't know what the equivalent command is in FME. Feature merger doesn't work because I don't have a common field in both tables ie. AssetID in one table and AssetID in another. So basically it is a join on the geometry I am trying to do. What is the best way to do this?
Best answer by erik_jan
A join on the geometry can be done using the NeighborFinder, one of the Overlayer transformers (AreaonAreaOverlayer etc) or the SpatialRelator.
Many options to do a spatial join (and I am sure I missed some more).
erik_jan
Forum|alt.badge.img+26
  • July 18, 2016
gisgeek
  • July 21, 2016
Spatial Relator was the best option and got the results I wanted - thank you
