How to extract in a shape the largest polygon each time an attribute changes value ?
  • Jan 19, 2018 3:19 PM UTC
  • 75 views
Exemple
nom surface
2 15
2 20
4 60
4 30
6 15
6 30
6 20
Result
Nom surface
2 20
4 60
6 30
danilo_fme
Forum|alt.badge.img+58
  • Jan 19, 2018 3:38 PM UTC
Hi @pedro
You can use the transformer StatisticCalculator to extract the max value:
Thanks,
Danilo
danilo_fme
  • Jan 19, 2018 3:39 PM UTC
Hi @pedro
Thanks,
Danilo
Option Group By = Nom
  • Jan 20, 2018 2:51 AM UTC
Hi @pedro, alternatively, if the attribute 'surface' stores the area of the polygon, you can sort the features by 'surface' descending with the Sorter and then sample the first feature for each 'nom' group with the Sampler (Group By: nom, Sampling Rate (N): 1, Sampliing Type: First N Features). The DuplicateFilter (Key Attributes: nom) can also be used instead of the Sampler.
