How to assign a count of duplicate attribute values to a new attribute
  • June 17, 2016
  • 307 views
gmbutler2
Forum|alt.badge.img+10
I am trying to use a transformer that will look at a single attribute and return with a count value equal to the number of instances that the defined attribute has identical values being used within it. I tried the numeric count attribute created by a statistics counter, but that was not correct. Can anyone tell me what transformer can do this if any?
  • June 17, 2016
The StatisticsCalculator is a good choice. Set a group by on the attribute with identical values, then look at the Count attribute output in the Summary.
You will then get one feature per unique group by-value, including a count of how many times it occurred.
