How do you batch deploy multiple data sources into single Excel file?
larue
Forum|alt.badge.img+8
I am able to create separate Excel files for each data source processed in the batch routine (consecutively), but can't figure out how to append the output of each translation into one file. The schema is the same throughout.
Thanks,
@larue
Best answer by larue
Select all data sources /files at once in your reader(s) and then make sure to use the same attributes in the writer. I recommend putting a sorter before the writer.
gazza
  • July 29, 2021
If the file name is the same and the Excel writer has "Overwrite Existing File" set to No then data should be appended to the one file for multiple runs of the workspace.
larue
  • July 29, 2021
Hi @gazza,
I am getting one Excel file per data source (CAD file) and it doesn't seem to matter if the overwrite is selected. The names of the Excel files created are taken from each CAD file processed. It does not give me a filename like I have specified in this dialog box. To be clear, this happens when I use Batch Deploy, not a single workspace run.
Excel Writer
gazza
  • July 29, 2021
larue wrote:
Hi @gazza,
Excel Writer
I haven't used Batch Deploy before but apparently there is an "Retain Source dataset basename in destination path" option when running it. What do you have that set to?
larue
  • July 30, 2021
larue wrote:
Hi @gazza,
Excel Writer
I have tried a few things, including unchecking that feature, but no luck. Will experiment a little more with it, and hopefully I can find more documentation somewhere. Stay tuned!
larue
  • August 4, 2021
larue wrote:
Hi @gazza,
Excel Writer
Still can't figure this one out. Tried all different combinations of the Batch Deploy parameters and set Excel Writer to no overright but only get either one source translation or both in separate files.
larue
  • December 22, 2021
