How do i compare data rows from two tables accross two databases?
  • Sep 24, 2019 4:36 PM UTC
  • 69 views
How do i compare data row count from two tables across two databases? Basically i am trying to load data if source has more rows than target table.
danilo_fme
Forum|alt.badge.img+58
  • Sep 24, 2019 4:57 PM UTC
Hi @rajan
Did you try to use the transformer FeatureMerger to compare?
Thanks in Advance,
Danilo
erik_jan
Forum|alt.badge.img+26
  • Sep 24, 2019 5:02 PM UTC
I created a workspace (without the data) that shows the workflow:
Hope this helps.
  • Sep 24, 2019 6:09 PM UTC
Thanks a lot for 1=1 trick was getting two separate rows and that was chocking point.
