How can you dynamically schedule an automation, based on a user parameter?
  • Dec 20, 2021 1:14 AM UTC
  • 132 views
I'm trying to schedule a flow based on an end user's chosen start time (which they'd pick and submit via an FME Server app).
To do this, I've built two flows: one that takes all the parameters (including a scheduled start time) and has a server app built in front of it; and a second one that actually does the heavy lifting and is either called via a webhook or is scheduled by FME Server.
I've tried to be clever and set a HTTPCaller at the end of the first flow to initiate a new once-off schedule in FME Server, but it's always failing with this error message:
	"message": "Unauthorized request by user admin due to lack of proper permissions or the object does not exist."
Any ideas? Or even thoughts on better ways to do this?
itsmatt
Forum|alt.badge.img+48
  • Dec 20, 2021 2:01 PM UTC
Your workflow here should work - I can't see any reason why it wouldn't. It will create a whole load of schedules though which might be a bit annoying. I guess you can always have another schedule to go and clean them up though - heh.
The message suggests that the token your using in the REST call doesn't have enough permissions, could it be this simple? Are you using a token or are use using the admin users credentials directly in the request?
You should also make sure that you are doing a POST request to create the schedule rather than a PUT or GET. A PUT or GET both assume the item already exists which could be where this message is coming from.
hkingsbury
Forum|alt.badge.img+73
  • Dec 20, 2021 7:30 PM UTC
Re the token, assuming you've left the admin creds as default it should be a superuser and therefore have access to any/everything on the server. Could be that your request is referencing something that doesnt exist?
