how can i Transform the 2D autocad file (dwg) to the CityGML ?
Hello,
I am trying to create a workflow in order to transform a dwg to a cityGML file and later to import it into a 3D citygml database. https://ometv.onl https://chatroulette.top https://omegle.wtf https://bazoocam.cam
I have tried to find an example online doing something similar but I had no luck.
I wanted to ask if something like this is possible with FME and if there is an available example to get a first impression of how to implement it.
thanks
alexsunny
muzhnasto
Forum|alt.badge.img+12
  • September 8, 2021
Hi I may be wrong but maybe if you provide sample data you will increase the chance of an answer to your question
JennaKAtSafe
Hi @alexsunny123​, FME can definitely convert 2D DWG to CityGML.
You should find this article helpful - it will be a starting point for an IFC to CityGML conversion: https://community.safe.com/s/article/bim-to-gis-intermediate-ifc-lod-300-to-lod-4-cityg. Please feel free to share your DWG for a quick example as well.
