How can I reformat xml data to form a m:m table?
  • Aug 5, 2014 6:18 AM UTC
  • 47 views
I am reading xml data with FME 2014 and attempting to rebuild a relational database model. I have an xml object "element " which has an m:m relationship with object "type". The xml looks like this...
 <element id="194070" >   <types>     <type id="445"/>     <type id="643"/>   </types> </element>
I can flatten the xml and recreate a table which looks like this...
 element.id | type.id.1 | type.id.2 194070          445         643
But in order to build a association table for the m:m relationship I need this;
 element.id | type.id 194070          445 194070          643
Can anyone offer a way to create this association table ?
  • Aug 5, 2014 11:08 AM UTC
If you read the XML document by the XML reader with Feature Paths option (Elements to Match: element), the reader feature type will configure a list attribute named "types.type{}.id". Then, you can use the ListExploder on the list "types.type{}" to create the required data structure.
Takashi
gio
Forum|alt.badge.img+15
  • Aug 5, 2014 11:31 AM UTC
You can Xquery the xml for "element" and send its childs to a list.
If you explode this list you get your m:m table.
Genius!
