How can I assign user parameters via a file? I have a large number of parameters and they all need to be pre-assigned. However, the content of the parameters can change. Therefore a variable solution is needed
  • Sep 18, 2023 1:54 PM UTC
  • 6 replies
  • 90 views
fbeginner
Forum|alt.badge.img+4
nielsgerrits
Forum|alt.badge.img+67
Yes you can, using a Python Scripted Parameter.
Create an .ini file, for example FmeConfig.ini with the following contents.
[Section1]
Setting1 = Value1
Setting2 = Value2
[Section2]
Setting3 = Value3
Setting4 = Value4
[Section3]
Setting5 = Value5
Setting6 = Value6
In FME, create a Scripted Parameter, Section1_Setting1.
import configparser
config = configparser.ConfigParser()
config.read(r'C:\TMP\FmeConfig.ini')
return config.get('Section1', 'Setting1')
This wil set the parameter Section1_Setting1 to Value1.
If you have a lot of parameters, this will take some time to set up, but it will do what you asked for.
fbeginner
  • Sep 19, 2023 5:24 AM UTC
Hello nielsgerrits,
Thank you for the quick reply. Das Script works nice. But now I have a new problem.
Sorry, I am just a beginner. When I pass words with umlauts (ä, ü, ö etc.) as values, they are not displayed correctly. Also an AttributeEncoder does not translate the values to UTF8.
Do you have a solution here too. Thank for your help.
nielsgerrits
Hello nielsgerrits,
Ah encoding, can you try if the following code works for you?
import configparser
with open(r'C:\TMP\FmeConfig.ini', encoding='utf-8') as f:
    config.read_file(f)
fbeginner
  • Sep 19, 2023 7:24 AM UTC
Hi nielsgerrits,
great, that's the solution. You are the best. Thanks
nielsgerrits
Hi nielsgerrits,
To be hones, I only implemented an ChatGPT answer, but if it works, it works :)
fbeginner
  • Sep 19, 2023 8:44 AM UTC
OK good idea, next time I'll also try chatGPT first, but if not I'll be back in the forum. Thanks 🤔
