how Agglomeration line in one pointn?
  • Dec 2, 2019 3:35 AM UTC
  • 41 views
charry
Forum|alt.badge.img+5
I want to put the line connection the Center point of rectangle?I dont know how to do?
  • Dec 2, 2019 8:58 AM UTC
One possible solution could be to send the rectangle into a CenterPointReplacer, then use the resulting point as the Anchor in the AnchoredSnapper, mode = End point snapping.
The line connections would be the Candidates. Then play around with the snapping distance.
