I have followed the below process .
First I used the Spatial Filter with electrical Line as a candidate and Electrical devices as filter and the spatial relationship as "Intersects".
Taken the failed records from the spatial filter to neighbour finder with base as device and Candidate as "Line feature ". Using the output of closest candidate X and Closest candidate Y , Vertex created with the replace point option to overwrite the geometry .
Tried the Anchored snapper as well which is not giving the expected result .
I am still seeing some of the devices are away from electrical line .
Can you please help me on fixing the issue ?
Thanks & Regards,
Kokila
Both ways should work. I think I would use the AnchoredSnapper. To get it to work you need to set a Snapping Distance. Is it possible that the points that are not moved are further away than the Snapping Distance? Did you set it at Segment Snapping or Vertex Snapping? Because if it is set to Vertex Snapping you might not get the expected result as the closest vertex is probably further away than the segment.
From the map I can see , the maximum distance I can see is 10 feet .With the anchored snapper If I choose Segment Snapping , with the snapping distance as 10 everything is coming under Untouched .
Don't know how it is ?
Regards,
Kokila
Attached image for reference
Regards,
Kokila
What for distance do you see when you measure in the Visual Preview / Data Inspector? My guess is the data has different units from what you see in the map? You might need to reproject the data to a projected coordinate system first, this can be done using a Reprojector.
