Hi, I need to convert the data from Oracle spatial to Microstation v8 using .net FME library (c#.net). I am facing problem while converting point features, it is coming as line feature (zero length) even though I set "igds_cell_name" and "cell librar
  • Apr 10, 2017 3:25 PM UTC
  • 78 views
erik_jan
Forum|alt.badge.img+26
  • Apr 10, 2017 4:55 PM UTC
Oracle Spatial can store point geometries in two ways (using SDO_POINT or using the SDO_ELEMENT_ARRAY).
If you are sure these are supposed to be point features (you might want to test on the number of vertices using the Tester counting the coordinates with @NumCoord:s = 1)
Then set the geometry to be a point using the GeometryCoercer before writing.
Hope this helps.
MicroStation stores points as zero length lines. There is no dgn point element type.
/Krister
