Geopackage writer and triggers issue
  • Jan 24, 2022 1:23 PM UTC
  • 7 replies
  • 174 views
jorge_rosales
Forum|alt.badge.img+8
If a execute this workspace:
imageUsing an existing (and empty) database with this trigger on parcel table:
imageI get this error:
There seems to be a conflict between the "prepared statement" used by FME and the trigger. Are they incompatible?
Note: This project is a simplified version of another in which the database schema and the logic implemented by the trigger are considerably more complex.
Best answer by markatsafe
@Jorge Rosales​  After a little digging and research, we don't think it's an FME issue. Modifying the trigger SQL slightly makes the trigger behave.  In SQLite, when inserting or updating data with a trigger, it seems you have to specify whether you are referencing the original record (OLD) or the update record(NEW). Adding this reference to the trigger SQL let's it run:
DROP TRIGGER "main"."parcel_insert";
CREATE TRIGGER parcel_insert
  AFTER INSERT ON parcel
WHEN (NEW.code IS NULL)
BEGIN
  SELECT RAISE(ABORT, 'Invalid parcel code');
END
Note the addition of NEW to line 4:
You should now only get an error if the replacement value for code (NEW.code) = <null>
I've attached a revised version of the workspace (FME 2021.2).
More details on SQLite triggers and the OLD | NEW references here
@Jorge Rosales​ Thanks for including the nice example workspace and test Geopackage. I was able to reproduce the ERROR. I'm not sure what is causing conflict between the table insert and the trigger. I've asked our development team to look at the issue and I'll report back.
jorge_rosales
  • Jan 24, 2022 7:31 PM UTC
Thank you very much @Mark Stoakes​, I'm waiting for news.
@Jorge Rosales​ It looks like this issue arises in the underlying GDAL Geopackage driver FME uses for the the Geopackage format. We're trying to trace down source issue
caracadrian
Forum|alt.badge.img+23
  • Jan 27, 2022 6:38 AM UTC
From what I can tell FME doesn't like the "parcel_insert" trigger.
I you delete it (via DB Browser for SQLite) and validate "code" attribute via a transformer, FME is able to write in the table.
jorge_rosales
  • Jan 27, 2022 7:18 AM UTC
Thanks for the update @Mark Stoakes​. If it is confirmed, I hope that the GDAL team fixs the error.
  • Feb 7, 2022 10:39 PM UTC
BEGIN
END
jorge_rosales
  • Feb 8, 2022 3:58 PM UTC
You are right. Thank you very much for the support @Mark Stoakes​
