Featurereader . WMS not giving the right results
  • Sep 22, 2022 11:08 AM UTC
  • 64 views
michiedem
Forum|alt.badge.img+7
I am trying to read this wms-service/url using the featurereader (espg 3857): https://geoservices.knmi.nl/adaguc-server?DATASET=RADAR&SERVICE=WMS&&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&LAYERS=RAD_NL25_PCP_CM&WIDTH=1131&HEIGHT=489&CRS=EPSG%3A3857&BBOX=-199509.20245398767,6500000,1419509.2024539877,7200000&STYLES=radar%2Fnearest&FORMAT=image/png&TRANSPARENT=TRUE&&time=2022-01-05T14%3A40%3A00Z
Somehow this gives me the wrong return, what's more: If I change the date/time the result stays the same, which should not happen
Using the exact same url in the httpcaller and saving it as a .png gives me the proper result (but i dont want to be saving files).
Any clue what i might be doing wrong?
Forum|alt.badge.img+54
  • Sep 22, 2022 11:33 AM UTC
I can't recreate. Using the WMS reader gives me the same result as the HTTP Caller and ImageFetcher transformers. Changing the date gives different output
michiedem
  • Sep 22, 2022 11:47 AM UTC
That is really weird. Could you share your feauturereader settings?
  • Sep 22, 2022 12:54 PM UTC
My settings are as per your screenshot and adding the RasterToPolygonCoercer after results in 801 features. Might be a different version of the feature reader? I'm working in 2021.2 with version 13 of the FeatureReader
