I want to merge two features with FeatureMerger (Attributes only). The requestor is an Oracle spatial featuretype, the supplier an Oracle non-spatial featuretype. Although the geometry passes through a GeometryValidator, it is not written (Oracle Spatial writer). I get: Bad geometry detected in the following feature; Geometry could not be encoded for Oracle. If the requestor and the supplier-feature are both Oracle-spatial, it works just fine.
