Feature Reader doesn't recognize UTF-8 encoded filename/filepath
  • April 17, 2024
  • 26 views
rishi1804
Forum|alt.badge.img+4
In my workbench I download ffs file from azure storage and assign the path in attribute _download_path then try to read the file from the same path using FFS reader but it’s not recognizing the path and in the error even showing wrong name like it’s replacing some characters like it’s considering the wrod gelöst as gelo?st. This word is in my filename.
jkr_wrk
Forum|alt.badge.img+29
  • April 17, 2024
Would you be able to read the filenames in MSDOS style?
https://en.wikipedia.org/wiki/8.3_filename
Is there a setting for character-encoding you could set to utf-8?
