Hello there!
I have a little problem with solving this issue.
need to create a geometry (with creator) which should be used as an "selector" maybe via intersect or overlap of features.
This features are comming from featureReader (ArcGis-Online Portal).
They should be intersected (or overlapped or similar) with created geometry, and as a result should be plain Excel Data, that inhalts only interected features.
The problem is, that in my result excel data are no features inside.
It looks like the were no "intersection". No features in created geometry. (but they are there) . I tried it with intersection and also with overlapping .
Not pretty sure what is the problem. Maybe I just do not see some setting?
the result Excel is included
Any Ideas?
Thanks
It's hard to say really, but there's a few things you can check:
  1. Try the Initiator contains Result as well.
  2. Does the geometry look ok after the ESRIReprojector?
  3. Is it actually in the same coordinate system as the ArcGIS data? (FME will not reproject on the fly)
  4. Is there actually data in that spot?
What does that $GEOM parameter look like?
