Extruding a Circle
I need to extrude a cicle feature to a given depth but the extrude transformer does not appear to work on an ellipse feature. Is there another way to tackle extruding this feature using FME?
davideagle
Forum|alt.badge.img+21
  • March 6, 2013
Try using the GeometryCoercer to coerce the feature to a polygon and see if that works for you.
sigtill
Forum|alt.badge.img+24
  • March 6, 2013
On some difficult DWG geometry I have also used ArcStroker to convert to a better geometry for further processing.
