Extract info from wensite using HTTP caller
  • Nov 20, 2022 10:06 AM UTC
  • 80 views
checcosisani
Forum|alt.badge.img+14
Hi
I tried to read this website
https://stilo.comune.torino.it/albopretorio/#/albo/59
but in the response body I don't have the info Pubbl. N°Atto N°Dettaglio (probably some javascript are present but I' not an expert..)
How can do this ?
thx
Francesco
hkingsbury
Forum|alt.badge.img+73
  • Nov 20, 2022 6:52 PM UTC
Looking at the calls the website makes, this URL seems to be returning the information you're after (response is in JSON)
https://stilo.comune.torino.it/albopretorio/dispatcher/alboPretorioServlet/invoke
checcosisani
  • Nov 20, 2022 7:12 PM UTC
Hi
if I copy the address that you provide I received this
so it means that isn't possible to extract/download the data ?
thx
Francesco
birgit
Forum|alt.badge.img+25
  • Nov 21, 2022 3:51 PM UTC
Hi
thx
Francesco
Yes because it is a POST request. You cannot just click on the link because you will send a GET request which is obviously not supported.
If you want to get the information from this site you need to understand the most common request type you have on the internet, how to use F12 on a site, how to export web request from your Developers tools (the thing that opens if you use F12). You also need to download Postman:
https://www.postman.com
And you need to learn how to import your web request into postman. If you have verified that the request works you can attempt to recreate the request in FME with the HTTP caller.
I am sorry I cannot give you a cookie cutter answer but every single web request is unique and requires time and effort even from people who have experience.
