explode xml string to features
I have a metadata string in a file and want to export this to its own attributes so I can export it to a database.
If i use the fragmenter it gives only <missing> as output. I have elements to match: gmi:MI_Metadata and expose gmd:fileIdentifier.
Same happens when i use the XMLflattener. I can't figure out what i'm doing wrong. Being stuck at this for a few days already. Only solution what worked for me was
  • Export to XML
  • Open XML in Sublime text to Replace &lt; for < and &gt; for >
  • Open the XML in a new workflow to extract to databases
Sometimes i get this message
message:prefix 'gmi' can not be resolved to namespace URI
Example:
<?xml version="1.0" encoding="UTF-8"?>
<!-- BAG Metadata - Created with: -vSABER_5.2.0.9.5ISO TC211 schema -->
<gmi:MI_Metadata xmlns:gmi="http://www.isotc211.org/2005/gmi" xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:gml="http://www.opengis.net/gml/3.2" xmlns:gco="http://www.isotc211.org/2005/gco" xmlns:xlink="http://www.w3.org/1999/xlink"  xmlns:bag="http://www.opennavsurf.org/schema/bag">
    <gmd:fileIdentifier><gco:CharacterString>19495cff-1e71-1b03-0ad9-03766b8b4567</gco:CharacterString></gmd:fileIdentifier>
    <gmd:language>
        <gmd:LanguageCode codeList="http://www.loc.gov/standards/iso639-2/" codeListValue="eng">eng</gmd:LanguageCode>
    </gmd:language>
    <gmd:characterSet>
        <gmd:MD_CharacterSetCode codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_CharacterSetCode" codeListValue="utf8">utf8</gmd:MD_CharacterSetCode>
    </gmd:characterSet>
    <gmd:hierarchyLevel>
        <gmd:MD_ScopeCode codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_ScopeCode" codeListValue="dataset">dataset</gmd:MD_ScopeCode>
    </gmd:hierarchyLevel>
    <gmd:contact>
        <gmd:CI_ResponsibleParty>
            <gmd:individualName>
                <gco:CharacterString>Paul L. Donaldson</gco:CharacterString>
            </gmd:individualName>
        <gmd:positionName><gco:CharacterString>Lead Hydrographer</gco:CharacterString> </gmd:positionName>
    <gmd:role>
                <gmd:CI_RoleCode codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_RoleCode" codeListValue="pointOfContact">pointOfContact</gmd:CI_RoleCode>
            </gmd:role>
        </gmd:CI_ResponsibleParty>
    </gmd:contact>
</gmi:MI_Metadata>
Can someone help me in the right direction?
Best answer by takashi
Hi @wilco,
you should be able to extract any values in an XML document with the XMLFlattener. Just be aware that the extracted attribute name will be a concatenated string that represents XML path, and you need to expose it.
You can see the extracted attribute names if you send the resulting feature to a Logger (Translation Log window) or an Inspector (Feature Information window of Data Inspector).
For example, if you set MI_Metadata to the Elements to Match parameter and run the XMLFlattener, extracted attribute names look like this.
  • March 12, 2020
Hi @wilco,
  • March 12, 2020
takashi wrote:
Hi @wilco,
Hi @takashi
I can only recreate your output if I export the string to a XML first and import the XML file to a flattener.
The XML is in a string of a BAG file. When I use the flattener to extract the string it outputs the whole string into 1 feature.
Im sure im doing something wrong, but I can't figure out yet what Im doing wrong to get the same output.
Forum|alt.badge.img+32
  • March 12, 2020
wilco wrote:
Hi @takashi
It doesn't look like you have exposed any of the attributes
You will need to enter the attributes to expose in the flattener
  • March 12, 2020
Thank you @takashi and @ebygomm
Its working now :) It's a long xml document but it will be worth typing it out for further documents in the future!
Thank you a lot! now I can continue with my project
