error message from Json template: invalid expression: syntax error, unexpected ":", expecting "," or ")"
  • Dec 23, 2022 8:52 AM UTC
  • 126 views
geomax
Forum|alt.badge.img+3
Hello,
I am trying to create a Json schema using the Json Template but I receive the error: JSONTemplater_2 (XMLTemplaterFactory): The following error occurred near line 21, column 20 of the query:JSONTemplater_2 (XMLTemplaterFactory): invalid expression: syntax error, unexpected ":", expecting "," or ")"
JSONTemplater_2 (XMLTemplaterFactory): An error occurred while executing the 'PROPERTIES' query
JSONTemplater_2 (XMLTemplaterFactory): The following error occurred near line 6, column 9 of the query:
JSONTemplater_2 (XMLTemplaterFactory): An error occurred while executing the process-features function
If I validate my Json on line seems to be correct but in FME doesn't work.
Do you have some suggestion?
Attached the file that I am using
Thanks
Max
debbiatsafe
Forum|alt.badge.img+24
Hello @geomax​
You may have a typo on line 20 as the xs:int function is missing the closing parenthesis. Try adding another closing parenthesis to this line in the JSON template. For example, it should be:
"valueKph": xs:int(fme:get-attribute("speedlimit")),
geomax
  • Jan 9, 2023 8:49 AM UTC
Hello @geomax​
Hello @debbiatsafe​,
sorry for delay in my reply and thanks for your comment.
My field is already "string type" so how can I add something like "xs: .........." for string data type. I didn't find any example for it.
If I try something like "appliesTo": xs:string(fme:get-attribute("appliesTo")) doesn't work.
Thanks
Max
Forum|alt.badge.img+54
  • Jan 9, 2023 10:58 AM UTC
Thanks
Max
What are you trying to achieve? If your field is a string, it will be returned in quotes without the need for anything other than
If you want to ensure it is a string if the data type is not a string then you can use xs:string
geomax
  • Jan 11, 2023 3:26 PM UTC
Hello,
my goal is to copy the values present in the field "AppliesTo" (shapefile format) in the same field present in the Json schema.
After a check, there was an error in the file and, after normalization, I applied what @debbiatsafe​ suggested.
Thanks to all.
Max
