Enable feature caching between sessions
  • Jan 16, 2021 2:52 PM UTC
  • 244 views
townest
Forum|alt.badge.img+4
Is there a way to enable feature caching between sessions, so that the workspace doesn't need to be re-run after closing Workbench? Thank you.
Tyler
FME Workbench 2020.2.1.0 Win64
Best answer by tomf
Save your workspace as a template (.fmwt) (File > Save as Template...) and include feature caches:
templatethen just open the template the next day. Your caches should be there for you.
tomf
Forum|alt.badge.img+31
  • Jan 18, 2021 12:21 AM UTC
@townest​  This is when judicious use of collapsed bookmarks is helpful. When you collapse a bookmark, feature caching for all the contents of the bookmark is turned off, so this will significantly improve performance, but also save on disk space when you store your workspace with caches as @tomf​ suggests.
townest
  • Jan 18, 2021 7:45 PM UTC
Thanks @tomf​ and @Mark Stoakes​. If I do use the fmwt what is the best practice for converting back to fmw? Thanks again. Tyler
@townest​ just open the fmwt in FME Workbench and it'll open the cache files.
