Dynamic Schema - wrong attribute order
  • Feb 9, 2024 10:31 AM UTC
  • 181 views
marta.podsiad
Forum|alt.badge.img+12
I have a gdb with pleanty feature classes with unique schema and I use SchemaScanner and Dynamic gdb to save the layers. Feature layers saved in the gdb have correct schema but the order of the columns is wrong, it looks like the new feature layers have the columns ordered alfabeticaly
nielsgerrits
Forum|alt.badge.img+67
Just to be sure, you read from gdb and you write to gdb? Why not use the FeatureReader and it’s Schema Feature? Because then the attribute order is kept original.
I can confirm the SchemaScanner does output the attribute order alphabetically.
marta.podsiad
  • Feb 9, 2024 11:14 AM UTC
FeatureReader does not read the attributes that I have to change
nielsgerrits
It does, but they are unexposed. Select a feature and see the Feature Information Window. You can expose unexposed attributes with an AttributeExposer. With FeatureCaching you now can easily import them from feature cache.
marta.podsiad
  • Feb 9, 2024 12:20 PM UTC
When I do that I get
Esri Geodatabase Writer: Feature Type Definition '' was requested, but not defined. Please visit https://www.safe.com/support
GEODATABASE_FILE writer: An error has occurred. Check the logfile above for details
