Dynamic buffer size from polygon
raabster
Forum|alt.badge.img+4
Hi all!
I have a polygon where every vertex/point (don’t know the correct termonology) has a xyz coordinate. I would like to create a buffer where the buffer size depends on the z-coordinate. Couldn’t figure it out how to do it. Anyone who can help me figure this out?
nielsgerrits
Forum|alt.badge.img+54
Not sure if I understand what you want. If you want to convert the polygon to points and then buffer the points by z value steps are:
  • Chopper to get individual points from polygon.
  • CoordinateExtractor to get _z from points.
  • Bufferer to buffer points. Choose _z for Buffer Distance.
If the points need to be connected back into one geometry, you can use the HullAccumulator to do this.
raabster
  • February 26, 2024
Thank you for your swift reply :)
To clarify, let’s say that I have this shape, called “base shape”:
“base shape”
If I use the bufferer transformer and set it to, say -10 meters, I get the orange line:
“base shape”+”constant buffer”
What I’m looking for, is to use the z-value at each “point” to get the green line:
“base”+”constant”+”desired buffer”
Hope that sheds some light at what I’m looking for. I’ll try your solution and see what that gives me, thank you once again :)
nielsgerrits
Thanks, a drawing like this always helps understanding the question :)
joepk
Forum|alt.badge.img+20
  • February 26, 2024
Hello, what an interesting question. The drawing helps a lot! I think we want to extract all vertices, calculate a centerpoint (using a CenterPointReplacer) and move all vertices distance z towards the centerpoint. Then we can rebuild the polygon using an AreaBuilder.
Moving the coordinates z meters towards the centerpoint is going to be the hard part. Is your coordinate system in meters?
nielsgerrits
I think this can be done using a Scaler? Or OffsetCurveGenerator.
joepk
  • February 26, 2024
I don't see any options in either the Scaler nor the OffsetCurveGenerator that allow for vertex-precise scaling of polygons. But I am using 2019.1, so I could be missing some functionality there.
I was thinking of something like this:
And then use the _angle attribute from the NeighborFinder combined with the z attribute to figure out the new x and y coordinates of each vertex. Then stitch it all back together using an AreaBuilder.
But if the Scaler route works, that is probably more viable.
nielsgerrits
This is how I solved it:
  • Geometry to attribute.
  • Explode polygon to points.
  • Extract Z from points.
  • Generate vertex id’s.
  • Restore polygon from attribute.
  • Offset polygon based on Z.
  • Explode polygons to points.
  • Merge both sets of points so you have the corresponding vertice id and z value.
  • Create polygon from points.
raabster
  • February 26, 2024
Yes it is
raabster
  • February 26, 2024
Wow, what a solution :)
Although when I run it with my own data I run in to this error message:
OffsetCurveGenerator_offsetter (TeeFactory): OffsetCurveGenerator_offsetter: @Buffer2 -- Parameter 'Buffer2' must be a floating point number -- 'BufferWidth' is not valid
Tester_FAILED_-1_84_Player (RecorderFactory): OffsetCurveGenerator_offsetter: @Buffer2 -- Parameter 'Buffer2' must be a floating point number -- 'BufferWidth' is not valid
Any idea what is happening there? Upon further inspection the flow doesn’t seem to behave correctly before this error message occurs. If you feel like it, please see attached file for the areas I’m working on.
raabster
  • February 26, 2024
If you do look at the data, you can try to use a buffer size of say 5% of the z-value of each vertex as an example. Or whatevery you feel like :)
joepk
  • February 26, 2024
I also managed to complete my workflow. I calculated the new coordinates of each vertex using these formulas:
x_moved = x + z * cos(degToRad(angle))
y_moved = y + z * sin(degToRad(angle))
Haven't done anything this close to high school trigonometry in quite a while, so I might have made a little error somewhere, please be mindful of this 😊
Have a nice day!
nielsgerrits
The shapes you attached are 2D, so it is missing the 3rd coordinate you wanted to use to shift the points :)
I think @joepk his idea is better than mine.
nielsgerrits
Have a nice day!
As an alternative, draw a line from the point to the centerpoint, then use a Snipper to snip to a point on the line using the _z value.
joepk
  • February 26, 2024
Have a nice day!
I think I have missed something, This workspace will perform an inward buffer with positive Z-values and an outward buffer with negative Z-values. I think you have to add a -1 to the formulas somewhere:
x_moved = x + (-1 * z * cos(degToRad(angle)))
y_moved = y + (-1 * z * sin(degToRad(angle)))
raabster
  • February 26, 2024
I’m sorry for the error. zipped the wrong files… :(
raabster
  • February 26, 2024
Thank you both for your effort and help! Much appreciated!
geomancer
Forum|alt.badge.img+47
  • February 26, 2024
Nice to see these different approaches. I came up with yet another solution, that does not use the centerpoint of the polygon. Instead it bisects the inner angles of the original polygon (and it also works when the buffer distance is 0).
raabster
  • February 27, 2024
Nice! Thank you for your contribution 😀
