DWF Line Text to Shapefile Attribute
I have a dwf file with points and text (as line features). I'm trying to convert the data to a point shapefile and add the line text to the point as an attribute. In the image below the text '7086 PM' is actually just line features that make up the numbers and letters. Is there anyway to convert this to a shapefile and append the text as an attribute? If needed, I can share the dwf to get a clearer picture of what I'm trying to do.
danilo_fme
Forum|alt.badge.img+41
  • May 29, 2018
Hi @jfuto033,
Could you share the dwf file?
Thanks,
Danilo
  • May 30, 2018
danilo_fme wrote:
Hi @jfuto033,
Thanks,
Danilo
@danilo_fme the data shown in the image above comes from the PNTS-COGO feature.
danilo_fme
  • May 31, 2018
Hi @jfuto033
I'm try to convert line text to attribute using FME and Python.
