Display map scale in Data Inspector / Universal Viewer
  • August 29, 2013
  • 68 views
Dear community,
is there a way of displaying the map scale in the Data Inspector or Universal Viewer? That would help a lot, since we wouldn't have to write the data out each time to see how big the text/geometry is reality.
Kind regards
Thomas
  • August 29, 2013
as far as I know, this is not possible. You can, however, use the Mesure-tool to check size of your objects.
For the Data Inspector, be aware that you will need FME2013 SP2 for the Measure tool.
David
  • August 29, 2013
Hello David,
I suspected as much. If someone of Safe is reading in here:
Perhaps you could add this to the viewer/inspector. Although FME is not a GIS, it might be useful for analyzing the output.
Kind regards
Thomas
