DGN - Custom complex line style are always solid in the result file
  • Oct 15, 2020 10:08 AM UTC
  • 61 views
I have a trouble trying to draw a dgn file containing custom complex linestyle (with cells), but the result is always a flat line.
But it works with simple custom linestyle containing only dash and dot.
I followed this documentation : http://docs.safe.com/fme/2019.0/html/FME_Desktop_Documentation/FME_ReadersWriters/igds/Custom_Line_Styles.htm
When I inspect the output DGN file with FME Data Inspector, the igds_style and the igds_style_name are correctly set.
But when I open the file in Microstation, these lines are solid.
Did someone know how to resolve this issue ?
Can FME deal with complex custum line ?
Some screenshots :
The linestyle in the seedfile :
linestyle_seed
The result in FME Data Inspector :
result_file_inspector
The result in Microstation (the blue line in North-Est is a custum linestyle too, but with only dash and dot, and it works) :
result_file_microstation
Note the FME Version is 2019.0.0.1.
Thanks for your help,
rlagarde
  • Oct 19, 2020 8:34 AM UTC
I'm also interrested in any answers regarding these custom line styles issues.
