I have a workspace that uses the custom FeatureCounter followed by a TestFilter. If too many features for my conversion I port to a Terminator transformer.
Following termination I want to delete the input file as part of a Python Shutdown script. The path including filename are in a Published Parameter. Example: [source_file]: c:\\folder\\file.ext
I've looked at lots of info but my attempts produce errors or the file doesn't get deleted, or both.
Can someone with good experience with this provide details on all lines needed in the shutdown script (and if needed, any Python needed in the body of the workspace)?
Thanks!
