Creating seperate attribute input for get-list-attribute in XML?
  • July 31, 2017
  • 6 replies
  • 124 views
Hello everybody, i have an xml file metadata, and i am converting it into another metadata standard. i have mapped both but problem is created by list values. I have attached two screeshorts,
the following screenshort will show the result. Attribute Name and datatype is getting value in list, but i want them as individual entry. How can I get it in final xml file?
Thanks
Best answer by takashi
Perhaps are you using FME 2016? Since FME 2016 treats the value of "_element_count" as a string, you will have to explicitly convert it to integer in the expression like this.
let $n := xs:integer(fme:get-attribute("_element_count")) - 1
My previous example was to repeat <CharacterString> element within a single parent element, but looks like it would not  match your desired result. If you need to repeat <column> element which contains <name> and <type> elements as its descendants, this example might be better for you. Assuming that the input feature has a list attribute called "attr{}.name", "attr{}.type".
<parent>{
for $i in (0 to $n)
let $aname := "attr{"||$i||"}.name"
let $atype := "attr{"||$i||"}.type"
return
    <column>
        <name>
            <CharacterString>{fme:get-attribute($aname)}</CharacterString>
        </name>
        <type>
            <CharacterString>{fme:get-attribute($atype)}</CharacterString>
        </type>
    </column>
}</parent>
input:
attr{}.name contains "foo", "bar", and "foobar"
attr{}.type contains "string", "integer", and "double"
result:
<?xml version="1.0" encoding="UTF-8"?>
<parent>
    <column>
        <name>
            <CharacterString>foo</CharacterString>
        </name>
        <type>
            <CharacterString>string</CharacterString>
        </type>
    </column>
    <column>
        <name>
            <CharacterString>bar</CharacterString>
        </name>
        <type>
            <CharacterString>integer</CharacterString>
        </type>
    </column>
    <column>
        <name>
            <CharacterString>foobar</CharacterString>
        </name>
        <type>
            <CharacterString>double</CharacterString>
        </type>
    </column>
</parent>
  • July 31, 2017
Hi @mjoarder_pln, this is a simplified example.
Assuming that a list attribute called "attr{}.type" contains these values,
attr{0}.type = string
attr{1}.type = integer
attr{2}.type = double
and the number of elements ("_element_count" attribute) has been extracted by the ListElementCounter beforehand, this XML template (XQuery) expression creates the following XML fragment.
(: XMLTemplater Template Expression Example :)
<dataType>{
let $n := fme:get-attribute("_element_count") - 1
for $i in (0 to $n)
let $attr := "attr{"||$i||"}.type"
return
    <CharacterString>{fme:get-attribute($attr)}</CharacterString>
}</dataType>
<dataType>
</dataType>
<dataType>{
for $i in (0 to $n)
return
}</dataType>
<dataType>
</dataType>
Hi, i have applied your code example in my ROOT Template example, but it is not working, please see the following two screenshort. xml_1 and xml_2.
No data is inserting inside xml...
I want to see the values like this:
All the different column names and data types will come inside their own parent elements.
Thanks
<dataType>{
for $i in (0 to $n)
return
}</dataType>
<dataType>
</dataType>
<bnr:MD_DataSchema>
  <bnr:column>
  <bnr:MD_Column>
  <bnr:name>
for $i in (0 to $n)
let $attr := "eainfo.detailed.attr{"||$i||"}.attrlabl"
return
  <gco:CharacterString>{fme:get-attribute($attr)}</gco:CharacterString>
  }</bnr:name>
  <bnr:description>
  <gco:CharacterString/>
  </bnr:description>
  <bnr:dataType>{
for $i in (0 to $n)
let $attr1 := "eainfo.detailed.attr{"||$i||"}.attrtype"
return
  <gco:CharacterString>{fme:get-attribute($attr1)}</gco:CharacterString>
  }</bnr:dataType>
giving me the following error:
XMLTemplater(XMLTemplaterFactory): The following error occurred near line 62, column 17 of the query:
XMLTemplater(XMLTemplaterFactory): arithmetic operation not defined between types "xs:string" and "xs:integer"
A fatal error has occurred. Check the logfile above for details
|ERROR |
  • August 1, 2017
<parent>{
for $i in (0 to $n)
return
    <column>
        <name>
        </name>
        <type>
        </type>
    </column>
}</parent>
input:
result:
<parent>
    <column>
        <name>
        </name>
        <type>
        </type>
    </column>
    <column>
        <name>
        </name>
        <type>
        </type>
    </column>
    <column>
        <name>
        </name>
        <type>
        </type>
    </column>
</parent>
  • August 1, 2017
<parent>{
for $i in (0 to $n)
return
    <column>
        <name>
        </name>
        <type>
        </type>
    </column>
}</parent>
input:
result:
<parent>
    <column>
        <name>
        </name>
        <type>
        </type>
    </column>
    <column>
        <name>
        </name>
        <type>
        </type>
    </column>
    <column>
        <name>
        </name>
        <type>
        </type>
    </column>
</parent>
This expression generates the same result.
<parent>{
let $names := fme:get-list-attribute("attr{}.name")
let $types := fme:get-list-attribute("attr{}.type")
for $i in (1 to fn:count($names))
return
    <column>
        <name>
            <CharacterString>{$names[$i]}</CharacterString>
        </name>
        <type>
            <CharacterString>{$types[$i]}</CharacterString>
        </type>
    </column>
}</parent>
<parent>{
for $i in (0 to $n)
return
    <column>
        <name>
        </name>
        <type>
        </type>
    </column>
}</parent>
input:
result:
<parent>
    <column>
        <name>
        </name>
        <type>
        </type>
    </column>
    <column>
        <name>
        </name>
        <type>
        </type>
    </column>
    <column>
        <name>
        </name>
        <type>
        </type>
    </column>
</parent>
Hi, takashi , it works! Thanks a lot ...
