Creating contours from ERSI ASCII Grid (ASC) data?
  • September 12, 2013
  • 72 views
darren
I've been given some free to use Digital Surface and Digital Terrain models consisting of TIF, ETW, XML and ASC files. I was wondering whether I would be able to create contours (in TAB format) from the included ESRI ASCII Grid files (ASC)?
Apologies if this is a bit of a daft question, I'm a bit new to all of this :)
Hi Darren,
I would use the RasterCellCoercer to transform the raster to 3D points, and then create contours using the ContourGenerator.
Takashi
You might be able to send the raster directly to POINTS/LINES port of the ContourGenerator.
ContourGenerator help: POINTS/LINES: These input features may be 2D or 3D, and may reside inside a raster, a point cloud, or other aggregate structures.
Takashi
darren
Hi Takashi,
Many thanks for the reply, it does look like you can send the raster directly to the ContourGenerator although I'm having a couple of issues with the output.
After experimenting with the parameters a little I've managed to generate a 5m contour file but am experiencing a large number of 'spikes'.  Could you suggest a way to minimise the spike effect?
Darren
fmelizard
Forum|alt.badge.img+18
It is possible that the spikes are actually locations of no data or extreme pixel values, I would try to resample the raster to possiy reduce nodata/extreme pixel values before generating the contours.
Itay
