Creating a personal ID as 3 letters and 6 numbers
  • Nov 2, 2017 6:54 PM UTC
  • 109 views
canerakin
Hey guys,
I checked this post below:
https://knowledge.safe.com/questions/56005/create-a-personalised-id-with-letter-and-number.html
it helped me, but I need to use 3 letters (I will specify) and 6 numbers. I used counter to generate the numbers and used string replacer to add the letters I want. However, I need to add zeros between letters and numbers. I need to something like:
ABC000001
ABC000002
ABC000011
ABC012341
Best answer by ebygomm
Take a look at the stringpadder to add the extra zeros to the left of your numbers and then join your letters to the numbers
erik_jan
Forum|alt.badge.img+26
  • Nov 2, 2017 7:04 PM UTC
After the Counter you can use the StringPadder to add zero's before the number to get it to 6 characters. The Use the StringConcatenator to add the number to the 3 letters for the desired output..
Forum|alt.badge.img+54
canerakin
  • Nov 2, 2017 7:11 PM UTC
Thank you guys,
have a good day!
gio
Forum|alt.badge.img+15
you can just use stringpadder on the number part.
length 6, pad 0 left.
Then concatenate with your suplied letters.
