Create polygon from OSM
  • Oct 20, 2022 10:33 AM UTC
  • 6 replies
  • 140 views
Hello,
I try to create polygon from osm like cemeteries. For now, I'm stuck after the XML Fragmenter and Vertex Creator. I don't know how to build lines between points because there isn't an unique value.
I didn't find anything on the FME community so I post this question.
If someone could give me an orientation, if would be very nice !
Thank you !
Best answer by itsmatt
Can you share the test.xml file? It could just be there is some more hidden information
Hey, right yeah seems there is somethign a bit weird going on when using the detfault settings.
I found I got more results if I used the "Output Incomplete Ways and Relations" settings. A lot more retsults here
itsmatt
Forum|alt.badge.img+48
  • Oct 21, 2022 1:37 PM UTC
hmmmm, Have you tried using FME's built in OSM reader? This might be a nice option for you.
You can save your request from the overpass HTTPCaller to a file rather than an attribute and then a the FeatureReader configured with The OSM XML Format to parse the results for you directly into FME features.
  • Oct 24, 2022 8:44 AM UTC
Thank @virtualcitymatt​  , with your idea, I progress a litlle bit. But as you can see (Itried with cemeteries and park), only 31 polygon (only parks) were build. And I don't have name or others informations. For the cemeteries nothing happens and in the featureReader, all features go to Unknown category.
imageHere the featureReader parameter
imageSo right now it's not so positive ! ;)
itsmatt
  • Oct 24, 2022 8:56 AM UTC
  • Oct 24, 2022 3:55 PM UTC
@virtualcitymatt​  what do you think about it?
itsmatt
  • Oct 25, 2022 8:55 AM UTC
  • Oct 25, 2022 3:48 PM UTC
Yes it works with it! It's better, it think I can progress now.
Thank you @virtualcitymatt​  for your quick answer!
