Create Lines from Point based on past features
  • February 27, 2015
  • 67 views
Hello,
I want to create lines from points based on the following:
1) Each feature contains an attribute with one of the following value:
A+, A or A-
2) Feature with A+ means start of the line
3) Feature(s) with A mean means continuation of the line.
4) A- means end of the line.
5) Another A+ means it will start a new line.
I know I can use point connector to connect the points. But, I am having a hard time on creating and then keeping it connected until I encounter A- to break it.
Any ideas?
  • February 28, 2015
These approaches flashed in my mind.
1. AttributeCreator with the "Prior/Subsequent Feature Attribute Retrieval (Multiple Feature Attribute Support)" option and the "Conditional Value" setting
(1) AttributeExposer
Attribute To Expose: _line_id
(2) AttributeCreator
Number of Prior Features: 1
If Attribute is Missing, Null, or Empty: Use Fallback Value
Fallback Value: 0
Attributes To Set (Conditional Value Setting):
_line_id = If _attr = A+ Then feature[-1]._line_id + 1 Else feature[-1]._line_id
(3) PointConnector (Connection Break Point: _line_id)
2. VariableSetter/VariableRetriever
(1) Sampler
Sampling Type: First N Features
Sampling Amount: 1
(2) VariableSetter (for the "Sampled" feature, i.e. the first feature)
VariableName: vLineId
Value: 1
(3) VariableRetriever (for every feature)
Attribute ReceivingValue: _line_id
(4) VariableSetter_2
Value (Conditional Value setting):
If _attr = A- Then _line_id + 1 Else _line_id
(5) PointConnector (Connection Break Point: _line_id)
3. PythonCaller
class FeatureProcessor(object):
    def __init__(self):
        self.line = None
    def input(self, feature):
        attr = feature.getAttribute('_attr')
        if attr == 'A+': # start
            self.line = feature
        elif self.line != None:
            self.line.addCoordinate(*feature.getCoordinate(0))
            if attr == 'A-': # end
                self.pyoutput(self.line)
                self.line = None
Takashi
  • February 28, 2015
Regarding the VariableSetter/Retriever approach, this may be smarter than the previous one.
