Create a list of dates based on starting date and interval
  • Mar 3, 2020 5:37 PM UTC
  • 6 replies
  • 411 views
Hello, I'm trying to download a series of excel files that are on a website. There is a starting date of 9/19/2005 (its hyperlinked for each excel file) and it increments by 7 days (so its a page fill of hyperlinked dates). I'm guessing I need to create a list of all dates starting from 9/19/2005 so that I can use httpcaller to download each file. I'm having trouble creating the starting date so that I can use DateTimeConverter to create the range (and consequently create the full url's to each file). I tried using AttrubuteCreator with a new value of DateTimeCreate(2005,09,19) but this expression errors.
Thoughts on this and I'm all ears if there is a cleaner approach. Thanks in advance
Best answer by erik_jan
A similar question and answer can be found here:
generating-date-and-time-columns
Hope this helps
erik_jan
Forum|alt.badge.img+26
  • Mar 3, 2020 5:40 PM UTC
Hope this helps
Hope this helps
Thanks erik, I'm looking through that workspace now and maybe I'll eventually get it but still quite confused. I changed the published parameter "Start Date" to be my 2005-09-19, however as i go through and alter this to fit my needs I get confused after the first cloner. I assume i basically need 780 "copies" since there is roughly that many weeks since year 2005. However after the first DateTimeCalculator how do i get it to generate a list of all those dates from my Start Date parameter through today?
erik_jan
  • Mar 3, 2020 7:36 PM UTC
I believe the DateTimeCalculator is set to add 30 minutes per record. You will need to change that to 7 days, multiplied by the _copynum from the Cloner.
Hope that helps. If not, let me know and I will try and change the workspace for your needs.
Thanks Erik, I think I have the days incrementing by 7 but it only does it once so can you show me how to incorporate the cloner so that i get a full list of dates going from my start date of 2005-9-19 through today? Here is a snipet of what my model looks like currently and I'm using FME 2019 desktop
34598-date-time-intervals.fmw
erik_jan
  • Mar 3, 2020 8:07 PM UTC
Try using the Arithmetic Editor and use 7 * @Value(_copynum) instead of just 7. That should work.
That worked! thanks
