Copy some attributes from a second source
  • May 15, 2017
  • 56 views
Apologies, This is a newbie question which shouldn't be this darn awkward to do.
I have two files A & B . Each have 3 attributes: NAME, ID, LABEL I want to copy A's NAME into B's LABEL based on the same ID.
I have been trying with Feature Merger. Join On for Requestor and Supplier are both pointing to the ID. A is the supplier. But the merged LABEL is not being overwritten.
any positive suggestions?
thanks kindly
Best answer by erik_jan
Use the AttributeRemover to remove the empty LABEL before using the FeatureMerger.
By default an attribute is not overwritten in the FeatureMerger.
erik_jan
Forum|alt.badge.img+26
  • May 15, 2017
  • May 15, 2017
Oy.
Thanks kindly again Erik.
I had actually been adding in the LABEL so that it could be overwritten.
cool stuff.
