cookie cutter
  • Mar 18, 2022 11:13 AM UTC
  • 116 views
Hello, I have vector data as gdb with multiple data layers: Communes Building Roads Green spaces I want to be able to cut out this data a bit like a cookie cutter according to the boundaries of the municipalities and group all the corresponding data, eg: Municipalities_01 Building (for this area) Roads (for this area) Green spaces (for this area) Municipalities_02 Building (for this area) Roads (for this area) Green spaces (for this area) Municipalities_... Building (for this area) Roads (for this area) Green spaces (for this area) Do you know how I can achieve this? Thanks very much
geomancer
Forum|alt.badge.img+71
  • Mar 18, 2022 12:11 PM UTC
Look into the Clipper and the AreaOnAreaOverlayer. These transformers both work like a cookie cutter in their own way. Depending on your downstream needs, one of them will probably be better suited.
