converting excel file into XSD fomat?
  • Jun 17, 2020 5:46 AM UTC
  • 6 replies
  • 612 views
I am looking for learning the way we can convert excel files into XSD format. Any basic tutorials/videos that can help me to learn this quickly?
Regards,
Purvi
Best answer by jdh
As far as I am aware there isn't an automatic xsd writer.
xsd however is just XML, so you could use an XMLTemplater to construct the relevant data.
Something along the lines of
Root (Creator):
<?xml version="1.0"?>
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
targetNamespace="https://www.w3schools.com"
xmlns="https://www.w3schools.com"
elementFormDefault="qualified">
<xs:sequence>
{fme:process-features("SUB")}
</xs:sequence>
</xs:schema>
SUB (your excel data):
<xs:element name="{fme:get-attribute("Field")}" type="{fme:get-attribute("Type")}"/>
Where type is generally one of
  • xs:string
  • xs:decimal
  • xs:integer
  • xs:boolean
  • xs:date
  • xs:time
so you may need to restructure your excel data (AttributeValueMapper)
If you have a nested data structure then you need to use complex elements, and will probably require multiple subtemplates.
jdh
Forum|alt.badge.img+41
  • Jun 17, 2020 9:41 PM UTC
Is your excel file a schema description or data?
FieldTypeIDIntNAMEString (50)
vs
IDNAME1John Doe2Jane Smith
  • Jun 17, 2020 9:47 PM UTC
vs
Hi @jdh, Yes that excel file is a schema at the moment.
Regards,
jdh
  • Jun 17, 2020 10:17 PM UTC
Root (Creator):
<xs:sequence>
</xs:sequence>
</xs:schema>
  • xs:string
  • xs:decimal
  • xs:integer
  • xs:boolean
  • xs:date
  • xs:time
  • Jun 17, 2020 10:39 PM UTC
Root (Creator):
<xs:sequence>
</xs:sequence>
</xs:schema>
  • xs:string
  • xs:decimal
  • xs:integer
  • xs:boolean
  • xs:date
  • xs:time
Thanks @jdh for your detailed answer. Do you have any workbench example template or tutorial to follow through this?
As I am really new to understand/create XML and XSD file format.
Regards,
Purvi
jdh
  • Jun 18, 2020 12:27 AM UTC
Regards,
Purvi
I've actually never written an xsd file. I would start with w3schools for an overview of the format. https://www.w3schools.com/xml/schema_intro.asp
For creating it in FME check out https://knowledge.safe.com/articles/30940/xml-writing-with-xmltemplater.html
  • Jun 18, 2020 12:37 AM UTC
Thanks @jdh, I will follow through this link to work on this... :)
Regards,
