convert scanned jpg drawing to dwg
  • Jun 8, 2020 4:45 PM UTC
  • 205 views
hi sir
good day
kindly could you confirm if you have software to transfer scanned drawing from JPG to DWG; so i can re modify the drawing. if yes, can you tell me the price of licencing.
danilo_fme
Forum|alt.badge.img+58
  • Jun 8, 2020 4:50 PM UTC
Hi @aymanmthabet
The Plataform FME has so many transformers that can extract pixels values from raster file, example JPG format.
For example - there is a link with working pixel value and extract to vector: Extract Pixel from Raster.
Thanks in Advance,
Danilo
This is a pretty easy process to set up but it will take some cleaning of the data afterwards depending on the input image. This may involve some smoothing of arcs and whatnot.
Attached fmwt file. - FME 2020.1
Example CAD floor plan PNG file.
Process
Original PNG
Convert to polygons
Dissolve polygons
Method 1 - Replace center lines (straight skeleton)
Method 2 - Replace center lines (Approximate center line)
New lines overlay on original PNG
