colored-jpg to grayscale-jpg
Hi, I am new here,
I tried to convert a colored „jpg“ raster image to „grayscale".
Until now i used the programm „IrfanView“, where I set the saturation-value to „-255“,
but i had to do it for every image seperatly.
Now I want to use FME for conversion of multiple pictures at once.
Could you help me to find the correct transformer for this work?
Or is there any other simply way to convert a various number of colored jpeg images into grayscale?
Thanks for answers ……
Best answer by takashi
Hi @chrst, the RasterExpressionEvaluator might help you. See the example 4 in this article to learn more: Simple Examples Using the RasterExpressionEvaluator Transformer
jdh
Forum|alt.badge.img+28
  • July 16, 2018
I personally use the RasterExpressionEvaluator to perform a weighted band conversion,
ex. 0.2989*A[0] + 0.5870*A[1] + 0.1140*A[2]
These values come from Rec.601, but there are several other standards.
  • July 16, 2018
  • July 16, 2018
Wouh, super, very helpful
Thank You
Greetings from our Dolomite Alps .......
