clipper result not as expected
  • Sep 28, 2018 10:53 AM UTC
  • 10 replies
  • 98 views
boubcher
Forum|alt.badge.img+11
Hello There I have 2 polygons, as you can see on the inspector both are into different location
all using projected coordinate when we using the clipper it inside results
how this is possible
danilo_fme
Forum|alt.badge.img+58
  • Sep 28, 2018 11:34 AM UTC
Hi @boubcher
I saw that the Reader Parcel.shp has the coordinate UTM84-37N and the other Source Boundary.shp has the coordinate UTM84-38N.
When I executed the Workspace the Source data:
The LOg File Inspector show this about the coordinate system predefined in FME Data Inspector:
The Result of Clipper Transformer:
Thanks,
Danilo
boubcher
  • Sep 28, 2018 1:47 PM UTC
Hi @boubcher
Thanks,
Danilo
@danilo_fme
then the clipper is right and the problem is the viewer ? showing the parcle into the wrong place ?
boubcher
  • Sep 28, 2018 2:03 PM UTC
Hi @boubcher
Thanks,
Danilo
@danilo_fme
when you add a bing background Map , then the pacel is completely out side could you explain
Thanks
danilo_fme
  • Sep 28, 2018 2:20 PM UTC
@danilo_fme
Thanks
I generated a Writer KML and the result in Google Earth:
  • Sep 28, 2018 2:55 PM UTC
Hi @boubcher, as @danilo_fme mentioned, the parcel and the boundary have different coordinate systems.
If the coordinate systems defined in the datasets are correct, those geometries don't intersect geographically. However, the Clipper just treats input features as geometric shapes without considering their coordinate systems, so the boundary would be clipped by the parcel. I think that's the situation you have observed.
If you need to perform clipping operation correctly according to geographic spatial relations, you will have to reproject the features into the same coordinate system beforehand.
boubcher
  • Sep 29, 2018 6:55 AM UTC
@takashi
both are in a projected coordinate system one is in zoon 37 and other 38 ,
to get accurate result cliping opration should be done on project object , and this is our case
am I missing anything ?
  • Sep 29, 2018 9:55 AM UTC
Since those are different zones, naturally the Clipper cannot perform geographically correct clipping operation. You need reproject them onto the same coordinate system before clipping.
danilo_fme
  • Sep 29, 2018 10:09 AM UTC
@takashi
Just completing that @takashi
mentioned here in Brazil for example We have region with 3 different zones in the same State. In this project we reproject these 3 zones for the same coordinate system.
boubcher
  • Sep 29, 2018 11:20 AM UTC
@takashi
if you remove the background Map, both will even with 2 diffrent projected coordinate overlap, and in the reel world they overlap
but when you add the background map, the parcel is not in the same place
if its projection problem the should not overlay even when we remove the background map
just trying to understand why is that
  • Sep 29, 2018 12:02 PM UTC
data inspector with background map reprojects features onto the same coordinate system. If those two features are overlap in the real world, the coordinate system defined in the dataset could be wrong.
