Changing cordinate system of CityGML
Hello there,
It's my first time dealing with CityGML. I am working on my university 3D buildings project and I am trying to figure out how change from EPSG:2180 coordinate system to EPSG:2179. I was trying to use CsmapReprojector, yet even tho FME considers it as success, there is no geometry after the process. I was also trying easy way to simply use writer, yet it losses additional atributes.
Also, is there any tool I can use to "mosaic" CityGMLs?
deanhowell
Forum|alt.badge.img+23
  • June 17, 2019
Hello @getern, in regards to your coordinate system issue, I had a similar issue so used a variable setter and reprojector and called it throughout my model when outputting data.
  • June 18, 2019
Thanks for responding for my call!
Here is the deal:
It might be casued by different software version (mine is 2018), yet there is no Coordinate_Variable and Coord_System_Retriever tool in my kit.
Even tho I managed to transform file to desired coordination system, all additional (I belive they are called generic) attributes didnt follow the file.
Forum|alt.badge.img+48
Here is the deal:
It looks like @deanhowell2009 renamed some transformers. I'm pretty sure his Coord_System_Retriever is a CoordinateSystemExtractor (storing the coordinate system identifier in an attribute), I am not sure about the Coordinate_Variable though.
Since you mention you don't have geometry afterwards I'm wondering if you have geometry to begin with. Could you doublecheck that?
  • June 18, 2019
Geometry is lost when I am using CSmapReprojector. While working with tools showed above geometry is fine. In fact I just dealt with problem of attributes as well.
Thank u guys for your help!
deanhowell
  • June 18, 2019
Just for clarification the transformer I renamed Coordinate_Variable is a VariableSetter and the Coord_System_Retreiver is a VariableRetriever transformer.
