changing amount of input layers
  • August 25, 2014
  • 47 views
I've created a workbench which has 3 input datasets. I would like to make it as universal as possible. Sometimes my datasets can be divided in to several shape files. If I created the workbench with only 1 shape file for each input dataset, it wont work if I put more shape files per dataset in the "prompt and run translation".
My work around has been to add new readers, but I would like to be able to do this directly with the prompt if possible.
Thanks for any ideas.
fmelizard
Forum|alt.badge.img+22
  • August 25, 2014
  • August 26, 2014
In addition, see also Single Merged Feature Type (or Merge Feature Type) option.
Adding Readers to the Workspace (http://docs.safe.com/fme/html/FME_Workbench/Default.htm#adding_source_datasets.htm)
Merging Feature Types (http://docs.safe.com/fme/html/FME_Workbench/Default.htm#Merging_Feature_Types.htm)
Takashi
  • August 26, 2014
Thank you so much for your support! I was thinking something too complicated. The solution was to have a folder for each of the 3 unique datasets, and then simply map to the folder and have *.shp. Then of course it no longer mattered did I have one or 20 layers when I ran the model.
Your inputs pushed me in the right direction!
