Change the field type from string to integer for all field automatically in writers
  • February 18, 2019
  • 5 replies
  • 207 views
Hi ,
I am wondering if there is a way to change the field type change the field type from string to integer for all field in writers in one go.
Like the screenshot below I manually changed the field type but sometimes I have a huge number of fields and need to have them in Int instead of string, Is this possible?
Cheers,
Rawan
Best answer by ebygomm
You can select all and then change the type and that will change everything
Forum|alt.badge.img+39
  • February 18, 2019
nielsgerrits
Forum|alt.badge.img+56
Learned something new today :)
  • February 18, 2019
Combined with the filter, it's then straightforward to bulk update attribute types. All that's missing is a select all button
  • February 18, 2019
Thanks it works fine !
Forum|alt.badge.img+50
Me too, I did not know that :)
